Welcome to the Avid MediaCentral | Cloud UX Help > Working with Audio > Working with Audio Tracks in a News Sequence > Panning for News Sequences
MediaCentral Cloud UX uses panning for news sequences as it is set in the Interplay Administrator.
NAT and SOT tracks: Mapped as odd tracks=left, even tracks=right. Source tracks for output are patched in the “Audio - Storyline Audio Patching” setting on the Editing Settings tab of the Application Database Settings.
VO track: Mapped as odd tracks=left, even tracks=right. You can center the VO track by selecting “Center-Panned Sound on Tape and VO” on the Editing Settings tab of the Application Database Settings.
These settings are saved in the sequence and are used for mixdown and send-to-playback (STP).
If Mix Mode is set for Mono, panning is ignored and all tracks are mixed into a single track for monitoring, which is played back in both output monitors (left and right). This setting is not saved with the sequence.
In the current release, the panning buttons are inactive.
*Complex (uneditable) sequences created in Media Composer use panning as set in Media Composer.
