Welcome to the Avid MediaCentral | Cloud UX Help > Browsing for Assets > Creating and Using Browse Favorites > Creating a Browse Favorite
The following process describes how to create a new browse favorite. Browse favorites are associated with your MediaCentral Cloud UX user account and not with your local workstation. If you work in an environment with multiple workstations, you can create a favorite on one PC, and then move to another PC later in the day — your browse favorite list follows you to the next session and workstation.
Note that you can create only one favorite at the same time. If your selection includes more than one folder — or an asset —, the Create Favorite feature is disabled.
To create a browse favorite:
1. Click the Directory button at the top of the Browse sidebar.
2. Use the Browse app directory and Results area to navigate to the folder for which you want to create a favorite.
3. Do one of the following:
*In the Directory, right-click on the folder and select Create Favorite.
*In the Results area, right-click on a folder and select Create Favorite.
If you right-click in an empty area of he Results area and select Create Favorite, the favorite will be created for the parent folder.
*Click the Favorites button at the top of the Browse sidebar and then click the “Add as a Favorite” button.
The New Favorite window appears. The name of the current folder is shown as the favorite name.
4. Enter a custom name.
You set the name of the favorite but do not change the name of the folder. You are not required to create a unique name for each favorite. If desired, you can have multiple favorites with the same name.
5. Click the Save button to save your new favorite.
Alternatively, you can click Cancel to abort the process.
The new favorite appear first in the list under the My Folders area.
