Welcome to the Avid MediaCentral | Cloud UX Help > Browsing for Assets > Selecting Assets in the Results Area
Clicking an item (shotlist, other asset, or folder) in the Results area selects and highlights it. Multiple items can be selected in different ways.
To select an individual item:
*Single-click (once) to select a single item.
*With an item selected, press the Up or Down arrow key; or the Left or Right arrow key (Card view only).
To select several non-consecutive items:
*Ctrl+click the items you want to select, regardless of order or arrangement.
The items are selected and highlighted.
To select several consecutive items:
*Click an item and then Shift+click the item that ends the series you want to select.
The items in the series are selected and highlighted.
*Shift+click an item above or below the highlighted selection.
The selection is expanded or narrowed.
*Ctrl+Shift+click an item above or below the highlighted selection.
The selection is expanded with the series of consecutive items.
*Click an item and then press Shift+Up or Shift+Down to select multiple contiguous items; in Card view you can also press Shift+Left or Shift+Right.
To remove the selection:
*Click outside an asset card (Card view) or row (List view) in the Results area.
*Click outside the selection.
