Welcome to the Avid MediaCentral | Cloud UX Help > Browsing for Assets > Working with MediaCentral Production Management Assets > Moving or Copying Folders
You can move or copy folders in the Production Management database by using drag and drop. You can move and copy folders from the Browse app’s Results area to the directory or within the Results area. Within the directory tree, you can copy or move one folder at a time. If there is already a folder with the same name in the target folder, a message opens and the folder is not moved or copied.
To copy a folder to another:
1. Select one or more folders.
2. Drag the selection to the folder into which you want to copy the folder.
The target folder is highlighted.
3. Release the mouse button.
The folder including its contents is copied.
To move a folder to another folder:
2. Drag the selection to the folder into which you want to move the folder.
3. Press the Shift key and release the mouse button.
The folder including its contents is moved.
