Welcome to the Avid MediaCentral | Cloud UX Help > Using the Collaborate App > Working Within the Media Container > Removing Assets from the Container
Complete the following process if you want to disassociate an asset from your topic or assignment. This process removes the media asset from the Collaborate app only, it does not delete the asset from the source MediaCentral module. If you remove a note created through the Notes Editor, the removal represents a permanent and unrecoverable deletion from the system.
To remove an asset:
1. Select the Media area of either your topic or assignment.
2. Do one of the following:
*Right-click on an individual asset.
*Shift+click or Ctrl+click two or more assets, and then right-click your selection to remove multiple assets simultaneously.
3. Select the Remove Asset(s) option from the context menu.
A confirmation dialog box appears.
4. Do one of the following:
*Click the Remove button to disassociate the asset(s) from your topic or assignment.
*Click the Cancel button to abort the process.
