Welcome to the Avid MediaCentral | Cloud UX Help > Editing a Sequence > Creating a Sequence > Audio-Only Shotlists
You can create and save an audio-only shotlist in the Asset Management database. An audio-only shotlist is a shotlist without video track, but with one audio track.
Note the following when creating an audio-only shotlist:
The sample rate is not evaluated and therefore you can create audio-only shotlists with mixed sample rates.
You can add segments only from an audio asset to an audio-only shotlist.
You have the same editing options as for shotlists with one video and audio track: trim, split, overwrite, replace, and delete.
You can also open and edit audio-only shotlists in Asset Management Desktop.
