Welcome to the Avid MediaCentral | Cloud UX Help > Editing a Sequence > Renaming a Sequence
Renaming a Sequence
In addition to being able to rename an asset in the Browse app, MediaCentral Cloud UX allows you to rename sequences directly in the Sequence Timeline. However, the ability to rename a sequence depends on the type of sequence and your permissions on the MediaCentral module’s source database. You cannot change the name of read-only, un-editable (complex) sequences, or draft sequences.
For more information on renaming assets through the Browse app, see Working with MediaCentral Production Management Assets and Working with MediaCentral Asset Management Assets.
To rename an asset in the Sequence Timeline:
1. Double-click the name of the sequence in the top-right corner of the Sequence Timeline and type the new name.
If you enter an illegal character, the text for that character is displayed as red. If you attempt to save the sequence with invalid characters, an error message appears and the name change is reverted.
2. Press Enter or click in another area of the user interface to save the change.
If you press the Escape key on the keyboard before saving the change, the name change is aborted and the original name of the asset is maintained.
When you change the name of the sequence, the name is not automatically updated in other areas of the user interface — such as the Browse app or the Asset Editor. You must refresh the display to see the change reflected in other areas of the UI.
