Welcome to the Avid MediaCentral | Cloud UX Help > Editing a Sequence > Recovering Sequences
When you work in MediaCentral Cloud UX, your edits and the current state of your sequence is periodically stored (every 10 seconds) on your local Windows or macOS system. Since the information is saved locally, your work is not lost in any of the following events:
A disconnection or service failure
You close a browser session without saving your work
Your session expires due to an automatic session timeout configured by your system administrator
Any edits made since the last ten second save interval cannot be recovered.
If a disconnection or failure occurs and you are required to sign back in to MediaCentral Cloud UX, you are met with an Auto Recovery window at the start of your new session.
This window displays any unsaved sequences or stories that were open when you were disconnected from the system. You can click on any of the items in the Auto Recovery window to load the asset.
When you click the link for a sequence, the asset is loaded in the Sequence Timeline area of the Asset Editor (must be opened manually) and three additional buttons are displayed above the sequence: Recovered, Saved, and Keep This.
Recovered: Click this button to open the recovered version of the sequence (from the local system).
Saved: Click this button to open the last saved file.
Keep This: Click this button to save the version that you display and delete the other version.
You can click the Recovered and Saved buttons multiple times to switch back and forth between the two versions of the sequence to compare them. After you have decided which version of the sequence you want to save, click the Keep This button to save the sequence.
*For information about recovering stories, see Recovering Stories In Case of Disconnect.
