Welcome to the Avid MediaCentral | Cloud UX Help > Editing a Sequence > Working with Sequences > Undoing and Redoing an Action in the Sequence Timeline
You can undo or redo an action in the Sequence Timeline, such as restoring a clip that you deleted. The undo/redo list is not saved after you sign out of a session.
To undo an action, do one of the following:
*Press Ctrl+Z (Windows) or Command+Z (macOS).
*Right-click in the Sequence Timeline and select Undo from the context menu.
To redo an action, do one of the following:
*Press Ctrl+Y (Windows) or Command+Y (macOS).
*Right-click in the Sequence Timeline and select Redo from the context menu.
