Welcome to the Avid MediaCentral | Cloud UX Help > Editing a Sequence > Working with Sequences > Trimming Segments in the Timeline > Trimming from the Top or the Tail of a Segment
You can use the current position of the position indicator to trim a segment from the beginning (top or head) or end (tail).
To trim from the beginning or end of a segment:
1. Move the position indicator to the frame that you want to trim.
2. Do one of the following to access the Sequence Timeline context menu:
*Right-click a segment to select it and any linked segments.
*(Sequences only) Ctrl+click individual segments of a Sequence.
*Right-click on the Sequence Timline’s timecode bar to trim all overlapping segments at the position of the blue position indicator bar.
*To deselect a segment, click in an unused part of the timeline.
3. Do one of the following:
*To trim from the beginning of a segment, select Trim Top from the context menu. Alternatively, you can press Shift+[.
*To trim from the end of a segment, select Trim Tail from the context menu. Alternatively, you can press Shift+].
*These keyboard shortcuts are designed for an American keyboard and might not work with other keyboard layouts.
