Welcome to the Avid MediaCentral | Cloud UX Help > Keyboard Shortcuts > Associations App Shortcuts
Keyboard shortcuts available when working in the Associations app are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section; the Focus column in the table specifies the section of the tab when that is the case. For more information on the tab, see Using the Associations App.
Shortcut
Description
Focus
Ctrl (hold) + Click
Used to select multiple non-consecutive relations
Relations area
Shift (hold) + Click
Used to select multiple consecutive relations
Relations area
Ctrl (hold) + Shift (hold) + Click
Depending on the last operation performed before with Ctrl+click, the selection range is extended or reduced
Relations area
Drag + hold Ctrl (Windows) or Options (macOS
Copy association to another association type.
Only dragging the association moves the association to another association type.
Relations area
Esc
(Association creation) Hide the “Drag here to select another association type” drop zone overlay that is shown as soon as the dragged selection is positioned in the Associations app
Associations app
Esc
Cancel the association creation
Association Type selection overlay
