Welcome to the Avid MediaCentral | Cloud UX Help > Keyboard Shortcuts > Log App Shortcuts
Log App Shortcuts
Keyboard shortcuts available when working in the Log app are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section; the Focus column in the table specifies the section of the tab when that is the case. For more information on the tab, see Working with the Log App.
Shortcut
Description
Focus
Ctrl+M (Windows)
Command+M (macOS)
Creates a span with one frame duration
Log app
Ctrl+I (Windows)
Command+I (macOS)
Creates a new span and sets the In point to the current timecode
Log app
Ctrl+O (Windows)
Command+O (macOS)
Sets the Out point to the current timecode
Log app
F2 through F11
Shift+F2 through F11
(if configured)
Inserts the configured button or dropdown value to the corresponding span column in the Visual Text area.
For a text component, sets the cursor in the text component in the Visual Logging area. If the component already contains text, the text is highlighted.
Only available if the shortcut keys are configured for the used session template.
Log app
Esc
Cancel placing a component
Template
Ctrl (hold) + Click
Select multiple button or dropdown values for applying a color
Template
Shift
Toggle the display inside the “Select a shortcut window” to show the shortcuts <Up-arrow>F2 through <Up-arrow>F11 or the shortcuts F2 through F11.
Template
Shift (hold) + Click
Toggle the display inside the “Select a shortcut window” to show and select a shortcut <Up-arrow>F2 through <Up-arrow>F11.
Template
