Welcome to the Avid MediaCentral | Cloud UX Help > Keyboard Shortcuts > Tasks App Shortcuts
Tasks App Shortcuts
Keyboard shortcuts available when working in the Tasks app are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section; the Focus column in the table specifies the section of the tab when that is the case. For more information on the tab, see Working with the Tasks App (MediaCentral Asset Management).
Shortcut
Description
Focus
Shift (hold) + Up Arrow
Shift (hold) + Down Arrow
Shift (hold) + Click
Used to select multiple consecutive tasks
Tasks List
Ctrl (hold) + Click
Used to select multiple non-consecutive tasks
Tasks List
Up Arrow
Down Arrow
Used to navigate to the previous task
Used to navigate to the next task
Tasks List
Home
End
Used to navigate to the first task in the Task List
Used to navigate to the last task in the Task List
Tasks List
Esc
Keep the already selected term
Task Details (Legal list, thesaurus)
Delete / Backspace
Delete the selected text or figures
Task Details
Ctrl + A
Select the entire text
Task Details (Text)
Ctrl + C
Copy the selected text
Task Details (Text)
Ctrl + P
Paste copied text
Task Details (Text)
Ctrl + X
Cut the selected text
Task Details (Text)
Ctrl + Y
(While the cursor is positioned in a metadata field and you have not saved your changes) Redo the action
Task Details
Ctrl + Z
(While the cursor is positioned in a metadata field and you have not saved your changes) Undo the input
Task Details
