Welcome to the Avid MediaCentral | Cloud UX Help > Working with the Log App > Working with Templates > Editing Components on Templates > Editing Common Component Settings
Component name and label are settings that are common to all components you add to a template. You change them for all components in the same way, as described in the following procedure. For Number, Rating, and Score components, name and label are the only settings you can change.
To edit common component settings:
1. (Optional) Change the component name. This will change the header of the corresponding column in the Text Logging area.
2. (Optional) Click in the Add a Label field and type a label. You can type 100 characters at maximum.
The label provides additional information on the component.
