Welcome to the Avid MediaCentral | Cloud UX Help > Working with the Log App > Working with Templates > Coloring Buttons and Dropdown Values
When you are creating or editing a template, you can assign colors to buttons and dropdown component values to highlight important elements. Each button and dropdown component value has gray assigned as default color.
To color buttons and dropwdown values:
1. Open the template and switch to edit mode.
2. Select the button or dropdown value to which you want to assign a color. You can Ctrl+click to select multiple button or dropdown values.
A color palette appears in the Visual Logging area header.
3. Click a color in the color palette.
The color is assigned to the button or dropdown value(s). The color palette is hidden.
4. Repeat steps 2 ands 3 for all buttons and dropdown values you want to color.
5. To change the color of a button or dropdown value, select the button or dropdown value and select another color from the color palette.
To decolor a button or dropdown value:
1. Select the button or dropdown value you want to decolor.
2. Click gray (left color button) in the color palette.
