Welcome to the Avid MediaCentral | Cloud UX Help > Working with the Log App > Logging Sessions
Logging Sessions
Use the templates you created to log sessions. The Log app provides two options:
Logging against the wall clock if there is no asset attached to the session.
You can later attach an asset to the logged session.
*Only sessions with an attached asset are indexed for search. Sessions that have been logged against the wall clock do not show up in the search results.
Logging an asset that is attached to a session.
Once attached to the session, the asset is loaded into the Asset Editor when you open the session in the Log app.
