Welcome to the Avid MediaCentral | Cloud UX Help > Working with the Log App > Adding Spans to a Sequence
Starting with version 2020.4, you can add spans to a sequence by a simple drag and drop operation from the Log app. For more information about sequences, Editing a Sequence.
*The term sequence is used generically to refer to an assembly of audio and video assets; it refers to any or all sequence types.
Note the following:
You can add spans only from a session with attached asset. Using spans from sessions that have been logged against the wall clock is not supported.
You can add one span at the same time to the sequence. Multi-selection is not supported.
When you add a marker — a span with one frame duration —, a segment that consists of 2 seconds before the marker and 2 seconds after it is created in the sequence.
To add a span to a sequence:
1. Open a logged session with attached asset in the Log app.
2. Open the sequence you want to edit.
3. Click the Asset Editor Timeline button to show the timeline.
4. Click a span in the Log app’s Text Logging area and drag it to the Sequence Timeline into the position you want the segment to appear in the sequence.
The timeline shows where the segment will be added and how it will affect the other segments in the timeline.
5. Release the mouse button.
A segment with the duration of the span is added to the timeline and the position indicator moves to the first frame of the next segment.
