Welcome to the Avid MediaCentral | Cloud UX Help > Working with Media > Using the Viewer Zoom Bar
The Viewer zoom bar is located below the Viewer timeline. You can use the zoom bar to enlarge a section of the Viewer timeline so that you can work more easily with long clips. By default, the zoom bar is set to display the entire clip in the Viewer timeline.
*The Viewer zoom bar is similar to the Sequence zoom bar (in the Sequence Timeline area), but the two zoom bars operate independently.
The Viewer zoom bar includes a position indicator that matches the position indicator in the Viewer timeline and is always visible, which is useful when you are zoomed in to a section of the timeline that does not include the timeline position indicator.
The following illustration shows the zoom bar set for an entire 6-minute clip. The timeline shows tick marks of different heights for ten seconds, one minute, and five minutes.
Circled, left to right: ten-second mark, one-minute mark, five-minute mark.
The following illustration shows the zoom bar set to show approximately two minutes in the timeline. This span is referred to as the zoom region. Notice that the position indicator is displayed in the zoom bar, but is not visible in the timeline.
You can click and drag the zoom bar through the clip to select any two-minute region.
You can click the position indicator in the zoom bar and jump to the position indicator in the timeline. The zoom region moves to include both position indicators and to enlarge the section of the timeline that includes the position indicator. The following illustration shows a two-minute zoom region that includes the position indicator.
You can click anywhere in the zoom bar to move the zoom region left or right.
If you drag the position indicator in the timeline, or if you play the loaded clip or sequence, the zoom bar and its position indicator match the movement in the timeline.
To zoom in to or out from a section of the Viewer timeline, do one of the following:
*Drag a zoom bar handle in to zoom in or out to zoom out.
*Press the Down Arrow key to zoom in by 50 percent or press the Up Arrow key to zoom out by 50 percent.
*Press Shift+Up Arrow to reset the zoom level to show the entire sequence.
*Position the mouse pointer over the timeline or zoom bar and rotate the mouse wheel forward to zoom in by 50 percent or rotate the mouse wheel back to zoom out by 50 percent.
