Welcome to the Avid MediaCentral | Cloud UX Help > Working with Group Clips > Working with Group Clips > Timecode and Group Clips
A group clip has its own timecode, which depends on the sync point and how the group clip was synced when created. The group clip takes its timecode from the first master clip in the bin when the group clip was created. If the master clips that compose the group clip share the same timecode and were synced by timecode, timecode for the group clip will match timecode for any of the active angles.
In multi-angle view, the group clip timecode is displayed.
In single-angle view, the timecode for the active angle is displayed.
Black filler is used as padding in angles that have different start or end points from other angles in the group clip. In single-angle view, master timecode for this filler is displayed as 01:00:00:00; absolute and remain timecode are displayed as blank.
For more information, see Using the Timecode Displays.
