Welcome to the Avid MediaCentral | Cloud UX Help > Working with Group Clips > Adding an Active Angle of a Group Clip to a News Sequence
Complete editing support for group clips is available only in shotlists. However, you can add the active angle of a group clip to a news sequence. The result is that the original master clip is used in the sequence, along with its original audio tracks.
The result is similar to using the Match Frame feature with a group clip, and then editing the resulting master clip into the sequence.
*All association with the group clip is lost when you add an angle to a news sequence. If you need this metadata, you must use a shotlist.
To add an active angle of a group clip to a news sequence:
1. Load a group clip into the Asset Editor.
2. Select the active angle.
3. (Optional) Mark In and Out points.
4. Drag the clip to the Sequence Timeline of a news sequence.
5. (Optional) Change the audio mapping by right-clicking the clip in the timeline, selecting Audio mapping 1 or Audio mapping 2, then selecting the desired audio track.
The default track is based on the MediaCentral Production Management settings.
