Welcome to the Avid MediaCentral | Cloud UX Help > Working with Queues and Stories in the Rundown App > The Rundown App
The Rundown App
In MediaCentral Cloud UX, you can create Newsroom Management stories, edit them in the Rundown app, and save them on a Newsroom Management server.
The Rundown app is synchronized with the Newsroom Management server. Queue and story modifications you make in the Rundown app are automatically updated on the Newsroom Management server. The reverse is also true: changes made on the Newsroom Management server are automatically updated in the Rundown app.
The Rundown app also automatically refreshes changes made in any queue on a local system, so that all users are able to see the latest saved status information. All queues will refresh in the Rundown app, independent of their assigned database traits on the Newsroom Management server.
Beginning with version 2019.9, multi-site support was added to provide the following functionality:
Open rundown (queues) on a remote Newsroom Management system.
Create, edit, and delete stories on a remote Newsroom Management system.
Open, assign, or unassign remote sequences to and from a news story. See Associating a Sequence with a Story.
You can access the Rundown app by clicking on the icon in the Fast Bar at the top of the user interface. However before you can use the Rundown app, you must load a Newsroom Management asset into the app.
To open a queue in the Rundown app:
1. Use the Browse or Search apps to find a Newsroom Management queue or story.
2. Double-click on the queue or story to open the asset in the Rundown app.
*You may use the Browse or Search apps to find both local and remote assets.
The asset opens in the Rundown app. If opened from the Browse app, the topmost story is selected. If opened from the Search app, the story you double-clicked in the Search results list is selected. You might need to scroll down in the queue to see the highlighted story.
Display or Control
Display or Control
1
Browse app (docked)
3
Queue section(also referred to as Queue grid)
2
Rundown header
4
Story section (Script Editor)
The Rundown app can display either a queue, such as a show's rundown, a story in that queue, or both.
To display the queue section, click the Queue button so that it turns blue. To hide the section, click the button so that it turns gray.
To display the story section, click the Story button so that it turns blue. To hide the section, click the button so that it turns gray.
The Rundown app can display a tab for each queue you open. The name on the tab changes based on the story you select in the queue. You can move the mouse pointer over the tab to view the entire path name.
*In addition to the story body, the story section may also display an area called the story form. The display of this section may be toggled on and off by clicking the Show/Hide Story Form options in the App menu.
When only the queue is displayed in the app, the display is called a grid view. When only the story is shown in the app, the display is called a story view. When both are visible, the display is called a split view.
You can use the horizontal dividing line between the queue and story sections of the app to adjust the ratio of the split view within the app. When you position your mouse pointer over the dividing line, the mouse pointer changes to a double arrow. You can then click and drag the dividing line up or down to adjust the space allocated to each section of the app. However, it is not recommended to use this technique to hide one section of the app or the other.
For Refresh queues, initially up to 250 stories are shown in the Queue section. If there are further stories in the queue, pressing the Show More Results button at the bottom of the Queue section lets you display the next 250 stories. Newsroom Management supports up to 1,000 stories in a Refresh queue.
