Welcome to the Avid MediaCentral | Cloud UX Help > Working with Queues and Stories in the Rundown App > Inserting Script Templates
Script templates are templates created by an administrator for you to let you quickly insert predefined text and segments into stories. For example, if a daily weather story in a show has a standard set of production cues and presenter instructions that are always the same, an administrator can create a script template that contains this information. The template can then be made available to MediaCentral Cloud UX users to insert within new stories they write for subsequent shows.
Script templates are inserted at the current cursor position of an opened story.
To insert a script template:
1. Position your cursor in the story body where you want to insert the template information.
2. Do one of the following:
*Click the Template button in the toolbar.
*Right-click and select Insert Script Template.
*Press Ctrl+Shift+I.
3. Select the template you want to use from the list by double-clicking on it.
