Welcome to the Avid MediaCentral | Cloud UX Help > Searching for Assets > Additional Search Options > Using Wildcards
Using Wildcards
The Search app allows you to use a question mark and / or an asterisk as wildcard characters in a text-based search. For information on using the tilde symbol ( ~ ), see Fuzzy and Proximity Searches.
*If you create a search using the Any or Markers and Segments search types with multiple terms in the same pill and you include a wildcard in the text, the rule that requires all terms to be found in the same field no longer applies. In this case the search might return search results based on the individual terms.
Question Mark
You can substitute the question mark ( ? ) for any single character in a text-based search. For example, if you enter Lo?d?n, your search results might include matches for London, Loyden, or others.
Asterisk
You can substitute an asterisk ( * ) to replace one or more characters in a text-based search. You can use an asterisk as the leading character, tailing character, or as a value in the middle of a term.
Consider the results for the following search terms. In this example, you can assume that the search index includes assets with the following names: fire, wildfire, wildfires, bushfire, frame
Search term type and value
Result
Any: fire
Returns: fire
No other assets are returned as the user did not add a wildcard as a leading character.
Any: wildfire
Returns: wildfire, wildfires
The search engine understands the use of plural words and returns both assets, even though wildfires is not an exact match.
Any: *fire
Returns: fire, wildfire, bushfire
The search returns the exact match, as well as all assets that end with fire. In this case wildfires is not returned because it is not a plural of “fire”. If you want the plural to be included in your search results, you might search for *fire* or *fire? instead.
Any: f*e
Returns: fire, frame
As the wildcard is used in the middle of the search term value, the search returns all assets that start with “f” and end with “e”.
