Welcome to the Avid MediaCentral | Cloud UX Help > Searching for Assets > Using the Results Toolbar and Search Results > Refresh Search
Refresh Search
The Refresh Search button updates the existing search results with any new assets that might have been created since the last time that you executed the search.
If you hover your cursor over the Refresh button, you are presented with the ability to enable an Auto-Refresh option that automatically updates your search results every 60 seconds. When in auto-refresh mode, you can still click on the Refresh button to manually update your search results.
*The 60 second refresh-rate value is hard-coded and cannot be customized.
If the auto-refresh fails to update the search results for any reason, a warning indicator appears to the right of the Refresh button. If you hover your cursor over the warning, a tool-tip appears that tells you how long it has been since the last update.
To enable auto-refresh:
1. Place your cursor over the Refresh button.
The Auto Refresh menu appear to the right of the button.
2. Click the Auto Refresh menu to enable the feature.
The menu turns blue to provide you with a visual confirmation of the change and the look of the Refresh icon changes.
When you move your cursor away from the menu, the menu disappears, but the Refresh icon maintains the updated look. Auto-refresh stays enabled until you do any of the following:
- Manually disable auto-refresh
- Clear the current search from the Search header
- Close the Search app
- Sign out of your current user session
