Welcome to the Avid MediaCentral | Cloud UX Help > Searching for Assets > Using the Results Toolbar and Search Results > Results Count
Results Count
This number indicates the total number of found assets. If your search did not return any assets, the count in the upper-left corner of the toolbar reports zero assets.
Although the results counter provides information on the total number of returned assets, the Search app can display a maximum of 1,000 assets in the Results panel at any one time. If you create a search that does not return your desired assets within the first 1,000 items, you must refine your search to narrow the results.
In the following example, the user created a very wide search for the letter “a”. The Search app found over 32,000 assets that included that letter, but it is only displaying the first 1,000 assets.
*In some rare cases, the app might not be able to determine the total results count (the value in parentheses). In these cases the value might appear empty or might show an “out of ?” message.
