Welcome to the Avid MediaCentral | Cloud UX Help > Searching for Assets > Using the Results Toolbar and Search Results > Sort By Menu
Sort By Menu
Although you might have already filtered your search, the Results view can be further modified by selecting an option from the Sort By menu. This menu is populated with a list of common sorting options followed by additional metadata fields grouped by type. A scroll bar appears to the right of the menu to allow you to move up and down through the list.
You can review the list of options by using the scroll bar on the right side of the menu. Alternatively if you are looking for a specific metadata value, you can use the filter option at the top of the menu to refine the list. If the term you use to filter the list returns too many values, you can enclose the term in quotes to look for an exact match value.
Additionally, you can use the Descending / Ascending menu to flip the results form top to bottom or bottom to top.
