Welcome to the Avid MediaCentral | Cloud UX Help > Using the Publisher App > Enhancing Video Clips and Other Media Assets > Adding Pre and Post Roll
Video Clips can be enhanced with Preroll and Postroll when the Edit Clip mode is active, using the Preroll or Postroll icons at the top of the Video Playback window.
To add Preroll and Postroll:
1. Click the Preroll icon to add Preroll or the Postroll icon to add Postroll.
The popup window will show existing “decorator” clips that are designated for Preroll or Postroll.
2. Click the Play icon to preview the Preroll clip, then when you locate the clip you want to add, click the “check mark” to select the desired Preroll clip.
3. (Option) If there is a new video available to use for Preroll, you can import it by clicking the Upload icon, then selecting the desired video file to upload (in MOV or MP4 format).
Once the video clip is selected, it will be appended to the final video clip created.
*The upload icon is shown by Administrator permissions only. The pre and post roll videos and images can be uploaded only from a local folder (not from a Production Management or Asset Management environment). Clicking the Upload icon opens up a Windows Explorer window.
4. (Option) Add a video transition to your Preroll or post roll. For more information, see Adding Video Transitions to Preroll or Postroll.
5. (Option) Add an audio transition to your Preroll or post roll. For more information, see Adding Audio Transitions to Preroll or Postroll.
