Showing and Hiding Columns
Processes are displayed in the Process List, which provides basic information on each process in several columns. The following columns are shown by default: Name, Message, Created at, Progress, and State. The Name column is mandatory and cannot be hidden.
You can change the display format of the dates shown in the Created at column in the User Settings. See
User Settings.
The Display Options menu shows you all columns that you can use in the Processes List area. Changes you apply to the Display Options menu persist from one session to another.
The Cancel and Retry buttons that might be shown for a process are located within the Progress column. If you hide the Progress column, you also hide these buttons.
You can reorder the columns in the Processes List area by simply dragging and dropping the column to a new position. Additionally, you can use your mouse to click on the divider between two columns to adjust a column to a custom size.
To show and hide columns in the app:
1. Click the Display Options drop-down arrow.
A list of columns appears. The columns that are currently used are highlighted with a blue check mark.
2. Select the columns you want to add or deselect the columns you want to remove. Name is a mandatory column that you cannot remove.
3. Do one of the following:
Click an area outside of the menu to apply your changes.
Press Esc to revert your changes.
To rearrange the column order:
Click and drag a column head to the left or right column.
A blue line shown to the left of the column indicates the drop target.
To adjust the column width:
Click the column divider and drag it to the left or right.
