Welcome to the Avid MediaCentral | Cloud UX Help > Working with the Process App > Using Basic Process App Features > Sorting the Process List
By default, processes are shown as a list in the Process app that is sorted by the Name column in alphabetical order. You can click on a column header to sort the Process List. Sorting is always applied to all displayed processes.
If displaying hierarchy and grouping is toggled on, the following sorting sequence is applied:
1. Groups are sorted first.
2. Within each group, top-level/parent processed are sorted first.
3. Within each top-level/parent process, the child processes are sorted.
To sort the app columns:
1. Click the heading of the column you want to sort by.
If the column can be sorted and how the column sorts the results depends on the content of the column. For sortable columns, an arrow appears in the column. You can sort the following default columns:
- The Name, Message and State columns sort results alphabetically, starting from the lowest number and the first letter.
- The Progress column sorts results starting from the lowest number.
- The Created at column sorts results by date, starting from the oldest date.
2. To reverse the sorting order, click the heading of the column again.
