Displaying and Editing User Task Data
You can view and edit task metadata in the Task Details area. Which metadata fields are shown and can be edited depends on the configuration of the task template in MediaCentral Asset Management.
To display and edit the task metadata:
1. Select a task in the Task List.
The Task Details area shows the metadata fields that are configured for the task.
2. Click in a metadata field and type or edit the value.
3. To save your changes, do one of the following:
Click outside the metadata field.
Click the Save button.
Press Ctrl+S (Windows) or Cmd+S (macOS).
If you do not save your changes and select another task, close the Tasks app, or log off, a message is displayed that asks you to save the changes.
