Welcome to the Avid MediaCentral | Cloud UX Help > Working with the Acquire App > Scheduling New Recordings > Adding or Removing a Destination
A recording can have one or more destinations defined. However, although each destination must use a different channel, they can share other parameters:
• If the source is routed, you can record the same content on more than one channel (e,g, splitting). Please note that some network streams may have limitations regarding splitting.
• You can store the media files all in the same location, or if different locations.
• You can create all the assets in one Production Management folder, or different folders.
• You can pick the same Ingest templates for every destination, or use different Ingest templates for each destination.
• All recording actions from different destinations are synchronized in time. The scheduling options defined in the Scheduling section are used. In other words, the destinations share the same time ranges.
*There is not an explicit Mirror feature. Instead, the user can define two destinations, both using the same source (input).
To add a new destination
1. To add a new destination, do one of the following:
*Click + icon. When you click this icon, the destination parameters will be taken from the defaults.
*Click the Clone Channel icon. When you click the Clone Channel icon, all the parameters will be copied except for the primary channel. This option helps with the creation of mirroring.
2. Edit the parameters for your new destination.
To remove a destination
1. To remove a destination, click the Trash icon:
The destination will be deleted.
