Deleting Recordings
After you have scheduled a recording, if you decide you no longer need that recording, you can delete it from the either Channels View or List View.
The Acquire app enables you to delete only future recordings.
To delete a scheduled recording:
1. Locate the recording you want to delete, and right-click the recording.
You can also select Delete in the Recording Details | Edit window.
2. Select Delete from the menu.
The Confirm Deletion dialog box opens.
3. Click the Yes button.
The recording will be deleted.
