Setting the Reference Level
You can set the reference level for the master volume output. By default the reference level is -20 dB, which means a tone of -20dB is displayed as -20dB. If you change the reference level to -10, a tone of -20dB is displayed as -10dB. You can set the reference level in the User Settings.
To set the reference level:
1. Click the User Profile button on the right side of the Fast Bar and select User Settings.
The User Settings dialog box opens.
2. In the navigation panel, select the settings group Video/Audio.
3. In the Output Reference Level section, complete one of the following actions:
Type a dB (decibel) level from -50 through -1.
Use the up or down arrows in the menu to select a new level.
4. Click Save.
