Deleting a Browse Favorites Team
If you want to delete a favorites team, you can do so through the Favorites tab in the Browse sidebar. When you delete a team, you also delete all favorites within the team. The ability to delete a team is restricted to system administrators.
To delete a favorites team:
1. Right-click on the team and select Delete Folder from the context menu.
A Delete Folder and Enclosed Favorites confirmation dialog appears.
The option to delete a favorites team is also available when you access the Manage Browse Favorites function.
2. Click the Delete button to confirm the removal of the team.
Alternatively, you can click Cancel to abort the deletion process.
