Renaming a Folder
You can rename Production Management folders in the Browse app’s Results area. Note that you cannot rename the top-level system folders.
To rename a folder:
1. In the Results area, slowly double-click the name of the folder and type the new name.
2. Do one of the following:
To save the changed name, click outside the field or press Enter.
To revert the changed name, click the Esc key.
