Moving or Copying a Folder
You can move and copy folders with their contents in the Asset Management Workspace by using drag and drop. You can move and copy folders from the Browse app’s Results area to the directory or within the Results area. Within the directory tree, you can copy or move one folder at the same time. If there is already a folder with the same name in the target folder, a message opens and the folder is not moved or pasted.
Your ability to move or copy a folder depends on Asset Management rules. The folder permissions in Asset Management Workspace must allow moving the selected folder and adding it to the target folder.
To copy a folder to another folder:
1. Select one or more folders in the Results area.
2.
Drag the selection to the folder into which you want to copy the folder.
The target folder is highlighted.
3. Release the mouse button.
The folder including its contents is pasted.
To move a folder to another folder:
1. Select one or more folders.
2.
Drag the selection to the folder into which you want to move the folder.
3. Press the Shift key and release the mouse button.
The folder including its contents is moved.
