Deleting a Folder
You can delete folders from the Asset Management Workspace in the Browse app. If you delete a folder, all the references to media assets that it contains will also be deleted. Check whether you need the media asset references contained in a folder before you delete it.
Your ability to delete a folder depends on Asset Management user privileges: the folder permissions in Asset Management Workspace must allow the deletion of the selected folder. If the folder contains subfolders, you also must have delete permission for each subfolder.
You can remove only one folder at a time. Multiple selection is not supported.
To delete a folder:
1. Select a folder.
2. Do one of the following:
Right-click and select Delete.
Click the App Menu button and select Delete.
A security prompt opens.
3. Click Yes.
If your credentials allow deleting folders, the folder is deleted.
