Renaming Asset References
You can rename the reference of shotlists and other assets in the Asset Management Workspace. Note that this action renames only the display name in the folder but not the shotlist or the asset itself. To rename the asset or shotlist, you must change its Main Title property in the Metadata tab. If you want to rename a shotlist, you can complete this same task in the Sequence Timeline. For more information, see
Renaming a Sequence.
Note also that the Asset Editor’s Media Viewer always shows the Main Title of an asset. If you only rename the reference of an asset in the Browse app but not its Main Title property, you will see different names displayed for the same asset in the Browse app and Media Viewer.
To rename an asset reference:
1. In the Results area of the Browse app, slowly double-click the name of the asset reference and type the new name.
2. Do one of the following:
To save the changed name, click outside the field or press Enter.
To revert the changed name, click the Esc key.
