Welcome to the Avid MediaCentral | Cloud UX Help > Keyboard Shortcuts > Browse App Shortcuts
Keyboard shortcuts available when working in the Browse app are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section of the app; the Focus column in the table specifies the section of the app when that is the case. For more information on the app and its sections, see Browsing for Assets.
Shortcut
Description
Focus
Up Arrow
Down Arrow
Used to navigate to the previous / next asset
Results area
Shift (hold) + Up Arrow
Shift (hold) + Down Arrow
Used to select multiple consecutive assets
Results area
Left Arrow
Right Arrow
Results area
(Card View only)
Shift (hold) + Left Arrow
Shift (hold) + Right Arrow
Results area
(Card View only)
Enter
If an asset is selected, opens the asset in the Asset Editor and in the defined default app (if applicable)
If a folder is selected, opens the folder contents in the Results area
Item in Results area
Enter
Esc
When renaming a folder or an asset:
• Enter saves the changed name
• Esc reverts the changed name
Name field (edit mode) in Results area
