Welcome to the Avid MediaCentral | Cloud UX Help > Keyboard Shortcuts > Storyboard Tab Shortcuts
Keyboard shortcuts available when working in the Storyboard tab are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section; the Focus column in the table specifies the section of the tab when that is the case. For more information on the tab, see Working with the Storyboard Tab.
Shortcut
Description
Focus
Ctrl+M (Windows)
Cmd+M (macOS)
(Production Management) Create a new marker (by default, a marker with a red icon)
Media Viewer
Storyboard tab
Browse app
Search app
Ctrl +number (top-row or numeric keypad)
(Production Management) Create a marker and set the icon color as follows:
• Ctrl+0: Last color picked. If no previous color was selected in a session, the color is white.
• Ctrl+1: Red
• Ctrl+2: Green
• Ctrl+3: Blue
• Ctrl+4: Cyan
• Ctrl+5: Magenta
• Ctrl+6: Yellow
• Ctrl+7: Black
• Ctrl+8: White
The NumLock state must be enabled to use these commands on the numeric keypad.
Media Viewer
Storyboard tab
Browse app
Search app
Ctrl+number (Windows)
Cmd+number (macOS)
(Asset Management) Creates a segment as follows:
• Ctrl+1 / Cmd+1: Opens a new segment and sets the In point to the current timecode
• Ctrl+2 / Cmd+2: Closes the open segment and sets the Out point to the current timecode
• Ctrl+3 / Cmd+3: Creates a segment with one frame duration
Media Viewer
Storyboard tab
Browse app
Search app
Shift (hold) + Up Arrow
Shift (hold) + Down Arrow
Shift (hold) + Click
Used to select multiple consecutive markers, restrictions, or segments
Storyboard tab
Ctrl (hold) + Click
Used to select multiple non-consecutive markers, restrictions, or segments
Storyboard tab
Up Arrow
Down Arrow
Used to navigate to the previous marker, restriction, or segment
Used to navigate to the next marker, restriction, or segment
Storyboard tab
Ctrl + Shift + Left Arrow
Ctrl + Shift + Right Arrow
Asset Editor Media Viewer
Ctrl + C
Copy the selected marker(s) or segment(s)
Storyboard tab
Delete
Delete the selected marker(s), restriction(s) or segment(s)
List view
Delete / Backspace
Delete the selected text or figures
List view (Integer, Float, Date, Time, DateTime, Text)
Enter
Positions the cursor in the Comment field of the selected marker or restriction
List view
Esc
Keep the already selected term
List view (Legal list, thesaurus)
Esc
Discard your input, keep the original value and end editing mode
List view (Date, Time, DateTime, Duration, Integer, Float, Timecode)
Up Arrow
Down Arrow
Increase value
Decrease value
List view (Date, Time, DateTime)
Up Arrow
Down Arrow
Move to the beginning of the field
Move to the end of the field
List view (Duration, Integer, Float, Timecode, Text
Up Arrow
Down Arrow
Move cursor to the line above
Move cursor to the line below
List view (Text (multi-line)
Home
End
Home
End
Move to the beginning of the line
Move to the end of the line
Left Arrow
Right Arrow
Advance to the input control at the left side
Advance to the input control at the right side
Left Arrow
Right Arrow
Advance to the character/figure to the left side
Advance to the character/figure to the right side
List view (Duration, Integer, Float, Timecode, Text)
Tab
Advance to the input control at the right side within the attribute
Tab
Exit edit mode of non-text attributes
*You cannot navigate between the properties of segments using the Tab key.
List view
Ctrl + A
Select the entire text
List view (Text)
Ctrl + C
Copy the selected text
List view (Text)
Ctrl + V
Paste copied text, duration, timecode
List view (Text, Duration, Timecode)
Ctrl + X
Cut the selected text
List view (Text)
Ctrl + Y
Redo the action
List view (Text, Float, Integer)
Ctrl + Z
Undo the input
Space
Checks or unchecks the in-focus check box
List view (Boolean)
