Editing Integer Properties
Integer fields accept only figures as input. How many figures you can type is limited by the property configuration of the data model; the maximum input number is 16 figures.
If you type more digits than allowed, a tool-tip appears. When you click outside the field, all figures that exceed the allowed range are trimmed to the correct number of figures.
To edit an integer property:
1. Click in the field to set it to edit mode.
2. Do one of the following:
To add figures, type the figures.
To change figures, highlight the figures and type new figures.
To delete figures, highlight the figures and press the Del or Backspace key.
To undo your input, press Ctrl+Z; to redo your input, press Ctrl+Y.
Press the Esc button. This discards your input and ends editing mode.
3. Click outside the property or press the Tab key.
4. To remove the value from the property, click the X button that is shown at the right side when you hover thew mouse-pointer over of the field.
5. (only required if auto-save is disabled) Click the Save button to save your changes.
