Welcome to the Avid MediaCentral | Cloud UX Help > Working with Metadata > Editing Metadata > Editing Legal List Properties
Legal lists provide the available values of a property in a drop-down menu. If you select from a legal list and type a letter, MediaCentral Cloud UX filters the list to all values containing that letter. As you continue to type, MediaCentral Cloud UX continues to filter the list according to the letters you type.
• For Asset Management, the values of a legal list are created in the Legal List Administrator app. Asset Management provides a set of preconfigured legal lists that you can use.
• For Production Management, an administrator has to create a custom property that includes a list of values from which users can choose in the Interplay Administrator application, before this list can be used in the Metadata tab. By default, no lists are configured in the Interplay Administrator.
To edit a legal list property:
1. To select a value, click on the list and do one of the following:
*Select a value from the list.
*Start typing the name of the value in the search box and then select the value from the filtered the list.
The list is collapsed and the selected item is shown as value of the legal list property.
2. To replace a value, click on the list and do one of the following:
*Select a new value from the list.
The list is collapsed and the selected item is shown as new value of the legal list property.
*To keep the already selected value, press the Esc key or click outside the list.
3. To remove a selected value from the legal list property, click the X button that is shown at the right side when you hover thew mouse-pointer over of the field.
4. (only required if auto-save is disabled) Click the Save button to save your changes.
