The Publish Sequence Timeline
If you load a sequence into the Asset Editor, the Sequence Timeline displays the sequence and allows you to edit the sequence prior to the final publish. You can use the trim controls on the timeline to adjust assets already contained in the sequence, or you can dock the Browse or Search apps to allow you to add new content to the sequence.
If you alter the sequence, you must save your changes prior to adding the sequence to any of the Publish endpoints. If you do not save, you receive an error when attempting your Publish job.
For more information on editing a sequence and using the Sequence Timeline, see
Editing a Sequence.
