Adding Markers & Segments to a Sequence
Similar to the workflow available in the Asset Editor’s Storyboard tab, the Timeline view of the In-Line Hits window allows you to drag Asset Management segments or Production Management Markers and Restrictions directly to the sequence timeline to help you expedite the editing process.
When you add a Production Management marker, the drag and drop operation creates a four second segment that consists of 2 seconds before and after the marker.
For additional information on the Storyboard workflow, see
Adding Storyboard Items to a Sequence or Container.
To add timeline hits to a sequence:
1. Locate an asset through the Search app and open the Timeline view of the In-Line Hits window.
2. Open the sequence that you want to edit.
3. Click the Asset Editor Timeline button to display the Sequence Timeline.
4. Click the Asset Editor Source/Record Monitor toggle button to switch Asset Editor to Source mode.
5. Click and drag the marker, restriction, or segment from the Timeline view of the In-Line Hits window to a point in the Sequence Timeline.
As a reminder, make sure to save your sequence when your edit session is complete.
