Setting the Default Save Location for New Subclips
You can set the default save location for new subclips in the User Settings. If you are working in a multi-site environment, the setting allows you to select a location in your local Production Management system only.
To set the default save location for new subclips:
1. Click the User Profile button on the right side of the Fast Bar and select User Settings.
The User Settings dialog box opens.
2. In the navigation panel, select the Save settings group.
3. In the Subclip section, click the drop-down menu and select the save location path.
4. Click Save.
