Deleting a Favorite Search
MediaCentral Cloud UX allows you to delete a single search or multiple searches simultaneously. You can use the following processes to delete one or more favorite searches.
Standard users can delete favorites from the My Searches area or any team folder to which they have read / write access. Only system administrators have the ability to delete Public favorites.
To delete a single favorite search:
1. (if necessary) Click on the Favorite tab in the Search sidebar.
2. Right-click on the favorite and select Delete Favorite from the context menu.
A confirmation window appears.
3. Click the Delete button to confirm the removal of the favorite.
Alternatively, you can click Cancel to abort the deletion process.
To delete multiple favorite searches:
2. Right-click in the space below the Create a New Favorite button and then click on the Manage Favorite Searches option in the context menu.
3. Click the check boxes to the left of all favorites that you want to delete.
You can select multiple favorites within the same folder or group, but after you select a favorite in one group, you cannot select a favorite in any other folder or group. For example, you cannot select a favorite in My Searches and a team folder simultaneously.
4.
Click the Delete button at the top of the list.
5. Click the Delete button to confirm the removal of the favorite.
6. Click the green check mark at the top of the list to exit edit mode.
