Opening Assets from the Search Results
After you complete a search, you can double-click on any asset to load it into another area of MediaCentral Cloud UX. Note the following:
• If you double-click a Production Management or Asset Management clip, the asset loads into the Source Monitor of the Asset Editor.
• If you double-click a Production Management or Asset Management sequence, the asset loads into the Record Monitor of the Asset Editor. If the Sequence Timeline is not already enabled, you must click the Timeline button in the Asset Editor to show the sequence in the timeline.
You can Ctrl+double-click (Windows) or Command+double-click (macOS) a sequence, to load the sequence into the Source Monitor.
• If you double-click a Production Archive clip or sequence, the asset loads into the Asset Editor. However due to the nature of archived assets, you are not able to play the media. In this case the Media Viewer reports that the media is offline.
• If you double-click on a Newsroom Management story, the asset is loaded into the Asset Editor. You can use the Tabs area of the Asset Editor to obtain more information about the asset. If you want to work with the story, you must first dock the Search app and open the Rundown App. For more information, see
Working with Queues and Stories in the Rundown App.
• If you double-click a Maestro News item or template, the graphic element is loaded into the Graphics tab and the Source Monitor of the Asset Editor. For more information, see
Working with Graphics Management Systems.
