Welcome to the Avid MediaCentral | Cloud UX Help > Keyboard Shortcuts > Rundown App Shortcuts
Keyboard shortcuts available when working in the Rundown app are listed in the following table. Some keystroke combinations only work when the cursor is located in a certain section of the app; the Focus column in the table specifies the section of the app when that is the case. For more information on the app and its sections, see The Rundown App.
Shortcut
Description
Focus
Ctrl+S
Save story
General
Ctrl+E
Toggle the story’s edit lock on and off
General
Shift+Left Arrow
Select text one character at a time moving backward
Story section
Shift+Right Arrow
Select text one character at a time moving forward
Story section
Shift+Up Arrow
Select text one line at a time moving upward
Story body
Shift+Down Arrow
Select text one line at a time moving downward
Story body
Ctrl+]
Split the segment
Story body
Ctrl+X
Cut selection
Story section
Ctrl+C
Copy selection
Story section
Ctrl+V
Paste selection
Story section
Ctrl+B
Set selected text to bold
Cue List/Story body
Ctrl+I
Italicize selected text
Cue List/Story body
Ctrl+U
Underline selected text
Cue List/Story body
Ctrl+Alt+P
Turn on Presenter Instruction mode or mark selected text as presenter instructions
Story body
Alt+Insert
Insert production cue
Story body
Shift+Alt+Insert
Insert primary cue
Story body
Ctrl+Alt+M
Mark selected text as machine control instructions
Cue List
Ctrl+Alt+C
Turn on Closed Captioning mode or mark selected text as closed captioning text
Story body
Ctrl+Alt+N
Turn on Normal text mode or change selected text to normal font
Cue List/Story body
Ctrl+Alt+G
Create a Story Group
Queue section
Ctrl+Alt+V
Dissolve a Story Group
Queue section
Tab
Move to next form field
Story form
Shift+Tab
Move to previous form field
Story form
Ctrl+Shift+I
Insert a script template
Story body
