Welcome to the Avid MediaCentral | Cloud UX Help > Working with the Storyboard Tab > Layout of the Storyboard Tab
The Storyboard tab provides features for editing and viewing time-based metadata of assets. The controls and properties displayed depends on the following:
Opened asset (Production Management or Asset Management asset)
Selected layer (markers or restriction, stratum, or thumbnail)
Selected Card or List view layout option
The following illustration shows a series of markers for the V1 track of a Production Management master clip in Card view layout. Displays and controls are described in the accompanying table.
Display or Control
Description
1
Reload button
Updates the display of markers saved for the selected clip or sequence resp. display of segments saved for the selected stratum. This control is especially useful when multiple loggers are adding markers to the same clip or sequence, or when a journalist wants to see the latest information added by the loggers.
Unsaved changes indicator
A diskette icon with a warning sign is shown to the right side of the Reload button when there are unsaved changes; for example, if you create duplicate markers.
When you hover he mouse over the icon, an “Unsaved changes” pop-up is shown. When the issue is resolved and all changes are saved, the icon disappears.
2
Layer selector
Lets you select the layer for which information is to displayed in the Storyboard tab. The top-most entry Thumbnails is always shown in the layer selector. Which other layers are displayed in the selector depends on the asset you open: Production Management or Asset Management asset.
When you open an asset for the first time during a session, the first layer below Thumbnails is selected. The selected layer persists when you switch between assets during your session.
Thumbnails
Thumbnails is the top-most entry and always displayed but it is not selected by default when you open an asset. It lets you show only the thumbnails of the asset open in Asset Editor. See Working with the Thumbnails Layer.
Track selector for Production Management assets
Lets you select the video or audio track for which markers are to be shown. For each video and audio track that is available for the asset open in the Assert Editor, a separate entry is shown.
The track selector provides the following entries:
All markers to select a read-only layer that displays all markers from all tracks.
V1...n to select the video track for which markers are to be shown.
A1...n to select the audio track for which markers are to be shown.
Restrictions to show only restrictions.
*You cannot currently show markers and restrictions at the same time.
Stratum selector for Asset Management assets
Contains the strata. The name of the selected stratum is shown on the collapsed list. When you open an asset in the Storyboard tab, the stratum that you used the last time for an asset of that asset type is automatically selected.
3
Create buttons
(Production Management only)
Create Marker buttons: Are shown if you select a Video or Audio track from the track selector. Click to create a new marker at the timecode selected in the Media Viewer. The buttons display the color of the marker to be added.
For more information, see Adding, Saving, and Deleting Markers.
Create Restriction button: Is shown if you select Restrictions from the track selector. If you have permissions to create restrictions, the button is enabled (left); if you do not have permissions, the button is disabled (right).
Create segment buttons
(Asset Management only)
Create Segment buttons: Are shown if you select a stratum from the track selector. If you have permissions to edit the stratum, the buttons are enabled (left); if you do not have permissions, the buttons are disabled (right).
Click to open, create, or close a segment at the timecode selected in the Media Viewer.
*In this release, you can only edit strata that allow overlapping segments. You can shown the segmentation for strata that do not allow overlapping segments but you cannot edit the segmentation or create new segments.
For more information, see Creating and Deleting Strata Segments.
4
List View button
Assets open in List view by default. In List view, markers and restrictions or strata segments are displayed without thumbnails. When the Thumbnails layer is selected, the List view button is disabled. When you switch from the Thumbnails layer to another layer, the Storyboard displays the asset in List view.
5
Card View button
Lets you display thumbnails for the selected Production Management or Asset Management layer. In Card view, the thumbnail associated with each marker or restriction resp. thumbnails for each stratum segment are shown. For more information, see Working with Card View Layout.
When you select the Thumbnails layer, the Card view button is automatically enabled and only the thumbnails for the asset are shown.
You can define the frequency of displayed thumbnails by using the drop-down arrow beneath the Card view button. For more information, see Thumbnail Options in Card View Layout.
6
Copy to Clipboard button
Copies all information of the selected marker, restriction or segment to the clipboard.
7
Download button
Lets you decide which marker and restriction or stratum information is to be downloaded and select the format of the download file.
8
Columns
Information on the asset open in the Storyboard tab is shown in a table with differing columns. Each row represents a segment in a stratum (Asset Management asset), or a marker or a restriction (Production Management asset). Which columns are displayed depends on the asset open and the layer selected from the layer selector control.
Columns that support filtering, show a Filter button. If filtering is enabled, the Filter button is colored blue. For more information, see Filtering Markers, Restrictions and Segments.
You can adjust the width of columns and rearrange the order of columns by dragging and dropping. When you adjust the Asset Editor width, the width of the Storyboard columns (except In and Out) is adjusted accordingly.
The default sorting in the Storyboard tab is by timecode, from lower to higher.
For a Production Management asset, the Storyboard tab shows the following columns:
In: Displays the timecode in the clip or sequence that corresponds to the location of the marker or start of a restriction.
Out: Displays the timecode in the clip or sequence that corresponds to the end of a restriction.
The In and Out columns show the span of the restriction.
Track: If the All markers layer is selected, the column indicates on which track the marker is located.
Comment: Displays the text associated with the marker or restriction. In edit mode, allows you to add or to modify text.
You can cut, copy, and paste this text. See Annotating Text Fields.
Color: Displays the icon associated with the marker. For a restriction, a warning icon is displayed.
Modified: Is shown for restrictions only. Displays the date when the restriction was created.
User: Displays the name of the user who created the marker or restriction.
For an Asset Management asset, the Storyboard tab shows the following columns:
In: Displays the start timecode of the segment.
Out: Displays the end timecode of the segment.
Properties: Displays the text or values associated with the segment. A separate column is shown for each property assigned to the selected stratum. You can edit the properties in List view. See Annotating Text Fields.
In and Out are shown for all strata by default, properties are shown according to the configuration of the stratum.
To open an asset in the Storyboard tab:
*Double-click an asset in the Browse or Search app and click the Asset Editor’s Storyboard tab.
*Right-click an asset in the Browse or Search app, in the context menu that opens select Open with > Asset Editor and click the Asset Editor’s Storyboard tab.
Until the asset is loaded in the Asset Editor, the Storyboard tab shows an “Asset is not loaded” message.
To update the information displayed:
*Click the Reload button.
The data is reloaded from the server and the Storyboard tab is refreshed. While the data is retrieved, the tab is dimmed and blocked for input.
To rearrange the column order:
*Click and drag a column head to the left or right column.
To adjust the column width:
*Click the column splitter and drag it to the left or right.
The width of the column is adjusted; the width of the other columns does not change. A horizontal scrollbar will be displayed if the columns do not longer fit to the width of the Storyboard tab.
To sort the column:
*Click the column head to sort in the following ways:
- In or Out, Timecode: lower to higher, or higher to lower.
- Track, Comment or User, Text: alphabetically, or reverse alphabetically.
- Color: in sequence of the Storyboard buttons shown on the toolbar from left to right, or right to left
- Numbers: lower to higher, or higher to lower
To switch between layers:
*To show only thumbnails, click the layer selector and select Thumbnails.
*(Production Management) To show markers, click the layer selector and select the track for which you want to show markers.
Alternatively, select the All markers layer to show all markers from all tracks.
*(Production Management) To show restrictions, click the layer selector and select Restrictions.
*(Asset Management) To show a stratum, click the layer selector and select the stratum for which you want to show segments.
