Welcome to the Avid MediaCentral | Cloud UX Help > Working with Audio > The Audio Tab
The Audio Tab
The Asset Editor’s Audio tab provides you with controls for monitoring and adjusting audio levels. Adjustments are saved for sequences in Record mode only. The status of the tab is persistent when loading new assets. For instance if you mute a track in the Audio tab and then you load a new asset, the track remains muted for the new asset. See the following topics:
• Working with the Audio Tab in Source Mode
• Working with the Audio Tab in Record Mode
